Normal Topic Error (Read 1893 times)
CodingJeff
Error
Jun 10th, 2007 at 3:01am
I get the following error and can't open the form that planner control is on. Any suggestions?
Object of type 'MindFusion.Scheduling.Style' cannot be converted to type 'MindFusion.Scheduling.Style'.
Hide
at System.ComponentModel.ReflectPropertyDescriptor.SetValue(Object component, Object value)
at System.ComponentModel.Design.Serialization.CodeDomSerializerBase.DeserializeAssignStatement(IDesignerSerializationManager manager, CodeAssignStatement statement)
at System.ComponentModel.Design.Serialization.CodeDomSerializerBase.DeserializeStatement(IDesignerSerializationManager manager, CodeStatement statement)
Re: Error
Reply #1 - Jun 11th, 2007 at 5:55am
This happens if Visual Studio uses one version of the calendar.dll in the form designer and loads a different version to generate the initialization code. Try removing the cached calendar.dlls from the following folders:
C:\Documents and Settings\***\Local Settings\Application Data\Microsoft\VisualStudio\8.0\ProjectAssemblies
C:\Documents and Settings\***\Local Settings\Application Data\assembly\
Replace *** with your account name.
I hope this helps,
CodingJeff
Re: Error
Reply #2 - Jun 11th, 2007 at 10:26am
Thanks, that seems to have resolved it.
