Normal Topic XmlWriter CultureInfo DecimalSeparator (Read 3679 times)
meriturva
Jun 26th, 2007 at 2:23pm
I have some pc with different languages and culture information....specially the decimal separator.
I would like to have the XmlWriter of the FlowCHart configurable about the decimal separator.
Without this control some pc views the diagram correctly others with so big table and fontsize.
I found that the set of Thread.CurrentThread.CurrentCulture doesn't affect the mindfusion xmlwriter.
I can change the decimal separator only setting into the Control Panel - > Regional Configuration-> English and the separator . or , and it works. If i set other languages i got only . (dot) decimal separator into the xml file.
How could i control the decimal separator into the MindFusion.Diagramming.Xml.XmlWriter?
Meriturva
My FlowChart.Net Professional version is 4.3.1.18498
Re: XmlWriter CultureInfo DecimalSeparator
Reply #1 - Jun 27th, 2007 at 4:52am
The XmlWriter class is designed to be culture-independent and it should not be affected by the current regional settings. I am testing here with different cultures and the produced XML files are always identical. What cultures do you test with? Any chance you can send me a saved XML file with comas (,) used as separators?
Thank you,
meriturva
Reply #2 - Jun 28th, 2007 at 5:01am
I have sent you an e-mail with two example, one with dot and one with coma.
They are two files empty but there are some general settings saved.
Note for example the Enviroment->Apparence one time is
<CrossingRadius>1,5</CrossingRadius>
in the other with the regional decima separator set to "." (dot) is
<CrossingRadius>1.5</CrossingRadius>
I have found that the problem is on only with English (UnitedStates) regional, with other languages it seems to be real culture indipendent.
I tested the normal XmlWriter from the framework with simple example and this is culture indipendend.
I think that the problem is that in mindfusion xmlwriter there are some double.ToString() that it is culture dependent.
Meriturva
Reply #3 - Jun 28th, 2007 at 6:56am
There was indeed a flaw in our XmlWriter, which is now supposed to be fixed in this prerelease build:
https://mindfusion.org/_431/_FlowChart.NET_trial431.zip
Let me know if it works.
meriturva
Reply #4 - Jun 28th, 2007 at 8:21am
I have the professional edition not the trial,
do i have to get the trial file you put here? and replace the ddls?
I don't want to get messed with license and so on
Meriturva
Reply #5 - Jun 28th, 2007 at 9:39am
The version I have posted above is a trial of the professional FlowChart.NET for .NET Framework 1.1. If you have purchased a licensed copy of the control, can you please e-mail us your order ID and we will send you the updated licensed version back through e-mail?
meriturva
Reply #6 - Jun 29th, 2007 at 5:27am
We have sent you an email with all information!
Thanks.
Meriturva
meriturva
Reply #7 - Jul 11th, 2007 at 12:52pm
seems to be fixed!
Thanks again!
Meriturva
