Normal Topic Move box for 1 pixel with mouse (Read 979 times)
meriturva
Sep 13th, 2007 at 5:38am
Hi to all,
i have to move boxes (with mouse) and i need precision about 1 pixel.
The FlowChart has the MeasureUnit in Pixel and no grid.
When i move the box for more than 1 pixel the box is moved correclty but when i move the box only about 1 pixel the box returns to the initial position.
How can i disable this funcion?
Meriturva
Re: Move box for 1 pixel with mouse
Reply #1 - Sep 13th, 2007 at 10:05am
Currently there is a hard-coded number of pixels the mouse should move before the control considers this a drag operation. Otherwise clicks often created reflexive links when the control did not use that threshold value. If you have upgraded to version 5, you can set the MouseMoved flag yourself by handling the MouseMove event and adding this code:
if (diagram.Interaction != null)
     diagram.Interaction.MouseMoved = true;
Then the control should let you move the box with 1 pixel.
