Normal Topic Scaling Question and Buttons Question (Read 3977 times)
Pallis
Sep 18th, 2007 at 7:15am
Hello Meppy,
I have 2 questions about PocketPlanner (TimeLine view)
1. Is there any way to autoscale the control to have the same appearance in devices with 640X480 screen as it has in devices with 320X240 screens ? Because in 640X480, the cells are very thin and the whole appearance looks shrinked. I am asking if there is a way to provide automatic resize without entering one by one the cells sizing, the timeline sizes e.t.c. and
2. I enabled control's navigation buttons but when i press them i would like to have a click event for these buttons. I can't find it. Can you tell me where are these events?
Thank you Meppy and as eval goes on you will bear me for a little more  Smiley
Re: Scaling Question and Buttons Question
Reply #1 - Sep 18th, 2007 at 7:40am
Unfortunately the answer to both of your questions is negative.
1) There is no way to automatically scale the contents of the control to fit the target display resolution. As you have guessed, settings the individual Size properties could resolve this issue. I think there are only several Size properties that need to be set.
2) As for the navigation buttons, they are not publicly exposed by the control. A not so elegant solution would be to traverse the Controls property of PocketPlanner and search for a button with the appropriate text, then attach an event handler to the Click event of the found button. The following code illustrates this:
foreach (Control c in calendar.Controls)
	if (c is Button)
		if ((c as Button).Text == "<")
			c.Click += new EventHandler(c_Click);
However, even if you handle the Click event, the PocketPlanner default navigation functionality will still be executed when the button is clicked, prior to your own event handler is invoked.
And feel free to post any other questions and comments about PocketPlanner. Smiley
Pallis
Reply #2 - Sep 18th, 2007 at 8:09am
Thank you very much Meppy !!
