Normal Topic Arrows got a shadow (Read 1189 times)
shil
Arrows got a shadow
Sep 24th, 2007 at 5:29am
Hi i set the shadow property to none, but if 2 arrows got the same location (1 segment) it looks like a shadow is drawn. is there any way to avoid that behaviour?
Re: Arrows got a shadow
Reply #1 - Sep 24th, 2007 at 7:25am
I cannot reproduce this. Perhaps the segments are not exactly overlapping and one of them looks as the shadow of the other? Or if you are using anti-aliasing, the line drawn where the segments overlap might look thicker than usual. That's some effect of GDI+ anti-aliasing; we cannot do anything to prevent it.
shil
Reply #2 - Sep 24th, 2007 at 7:53am
i found it. if you set  the smoothingmode to anit-aliasing, the arrows will draw thicker if they overlap.
thx for help.
