Hot Topic (More than 10 Replies) AttachToNode and detaching during modifying event (Read 8056 times)
koosala
Java Happens
Nov 2nd, 2007 at 6:15am
I have this requirement where two boxes must be attached to another bigger box when on the flowchart. When the bigger box is moved around the two boxes must move also.
This works alright for me.
I also need to detach the boxes if the bigger box is resized. So, I handle the ItemModifying event to detach the two boxes.
The boxes get detached alright,
But I get two problems with this:
1. If there is an arrow connecting the two smaller boxes, the arrow also moves with the bigger box.
2. The two boxes become unselectable after the resize. They can never be selected again.
I have attached the code here:
[code]
private void testContainment() {
Box three = new Box(flowChart);
three.setBounds(5, 5, 60, 60);
Box one = new Box(flowChart);
one.setBounds(10, 10, 15, 15);
Box two = new Box(flowChart);
two.setBounds(40, 10, 15, 15);
flowChart.addFlowChartListener(new FlowChartAdapter() {
@Override
public void itemModifying(ValidationEvent e) {
if (e.getItem() instanceof Box && e.getSelectionHandle() != 8) {
ItemList attachedItems = new ItemList();
for (Item item : ((Box) e.getItem()).getSubordinateGroup()
.getAttachedItems()) {
attachedItems.add(item);
for (Item item : attachedItems) {
((Box) item).detach();
if (((Box) e.getItem()).getSubordinateGroup() != null) {
.getAttachedItems().clear();
flowChart.add(three);
flowChart.add(one);
flowChart.add(two);
one.attachTo(three, AttachToNode.TopCenter);
two.attachTo(three, AttachToNode.TopCenter);
[/code]
Or if there is any other way I can fulfil my requirement?
Praveen
Re: AttachToNode and detaching during modifying ev
Reply #1 - Nov 2nd, 2007 at 7:20am
You will need to modify the source code again.
1. Add this to the FlowChart class:
public InteractionState getInteraction()
     return interaction;
2. Make the cancelModify method of Box public.
3. Add the following line after calling detach():
((Box) item).cancelModify(item.getFlowChart().getInteraction());
koosala
Java Happens
Reply #2 - Nov 2nd, 2007 at 9:27am
Hi Stoyan,
Thanks, this solves the problem 2, and the boxes are now selectable.
But the problem 1 is still present - the arrow connecting the two smaller box is still moving with the larger box.
Praveen
Reply #3 - Nov 2nd, 2007 at 9:36am
It did not move in my test, but maybe you can also call the arrow's cancelModify method to prevent that anyway.
koosala
Java Happens
Reply #4 - Nov 5th, 2007 at 1:03am
Hi Stoyan,
I have the following code now:
[code]
@Override
for (Arrow arrow : ((Box) item).getOutgoingArrows()) {
arrow.cancelModify(item.getFlowChart().getInteraction());
for (Arrow arrow : ((Box) item).getIncomingArrows()) {
flowChart.add(one);
flowChart.add(two);
[/code]
But inspite of this, the arrow connecting the inner two boxes continues to move.
Maybe I have older version of the source code then? If so, can you send me the current version, so I can check against that?
Praveen
Reply #5 - Nov 5th, 2007 at 10:17am
Hi Praveen,
I have sent you a PM containing the latest code.
koosala
Java Happens
Reply #6 - Nov 21st, 2007 at 3:06pm
Hi Stoyan,
I am sorry I have come back quite late after testing with the new source you gave me. Some other work held me up.
I still have the same problem. I have attached the code now where the arrow is also created during the initialization.
[code]
package research;
import javax.swing.JApplet;
import com.mindfusion.jdiagram.Arrow;
import com.mindfusion.jdiagram.AttachToNode;
import com.mindfusion.jdiagram.Box;
import com.mindfusion.jdiagram.FlowChart;
import com.mindfusion.jdiagram.FlowChartAdapter;
import com.mindfusion.jdiagram.Item;
import com.mindfusion.jdiagram.ItemList;
import com.mindfusion.jdiagram.ValidationEvent;
public class Goop extends JApplet {
private static final long serialVersionUID = 1L;
private FlowChart flowChart;
@Override
public void init() {
super.init();
flowChart = new FlowChart();
this.getContentPane().add(flowChart);
testContainment();
@Override
flowChart.add(one);
flowChart.add(two);
Arrow arrow = new Arrow(flowChart, one, two);
flowChart.add(arrow);
[/code]
I hope you get the same error I do, so at least I know I am not doing something wrong somewhere.
Praveen
Reply #7 - Nov 23rd, 2007 at 10:52am
We could not reproduce the problem. Here is our test project:
https://mindfusion.org/_temp/TestApplet.zip
What should we do when the test page opens to see the problem?
koosala
Java Happens
Reply #8 - Nov 26th, 2007 at 4:42am
Hi Stoyan,
To get the problem I am talking about:
1. Select the bigger outer rectangle.
2. Drag the left border of this rectangle to the right.
You will now notice that the bigger rectangle is on the top.
3. Move the rectangle away. You will see that the arrow has moved to the right.
I have tried this out with the sample you have sent me now.
Praveen
Reply #9 - Nov 26th, 2007 at 8:00am
We have tried this only with the right and bottom resize handles. I can see the problem now with the left one.
The arrow moves because the Group keeps a list of Arrow objects that should be modified too when the whole group is moved. So apart from calling cancelModify, try to remove the affected arrows from the group's "arrowsToMove" list.
For the next release we will add code that removes the affected arrows when the detach() method is called.
koosala
Java Happens
Reply #10 - Jan 28th, 2008 at 2:09am
Can you give me an approximate time I can see this change, or does 1.0.2 release have this fix already?
Praveen
Reply #11 - Jan 28th, 2008 at 6:40am
Since this is related only to your custom interaction code, our developers think it will be better to implement that there as well. Replace the loop that detaches boxes and removes them from the interaction list with the following:
Group g = e.getItem().getSubordinateGroup();
	Box box = (Box)item;
	for (Arrow a : box.getIncomingArrows())
		if (g.getArrowsToMove().contains(a))
			g.getArrowsToMove().remove(a);
	for (Arrow a : box.getOutgoingArrows())
fc.recreateCacheImage();
koosala
Java Happens
Reply #12 - Jan 31st, 2008 at 2:43am
Hi Stoyan,
That works very well.  Thanks.
I had to make
[code]
ItemList getAttachedItems()
[/code]
of Group public to get this done. Will your next release have this method as public?
Praveen
Reply #13 - Jan 31st, 2008 at 6:24am
Hi Praveen,
Yes, it is going to be a public method.
koosala
Java Happens
Reply #14 - Apr 12th, 2008 at 4:27pm
I am getting some other problems with this implementation. I have extended the example as shown below:
[code]
package research;
import java.awt.Color;
import com.mindfusion.jdiagram.Group;
import com.mindfusion.jdiagram.ShadowsStyle;
import com.mindfusion.jdiagram.SolidBrush;
@Override
super.init();
flowChart.setSelectionOnTop(false);
flowChart.setBackBrush(new SolidBrush(Color.WHITE));
flowChart.setShadowsStyle(ShadowsStyle.None);
testContainment();
Box four, five;
three.setBounds(5, 5, 90, 60);
four = new Box(flowChart);
four.setBounds(60, 10, 15, 15);
five = new Box(flowChart);
five.setBounds(160, 110, 15, 15);
@Override
if (e.getItem().getSubordinateGroup() == null) {
return;
if (box == four) {
continue;
flowChart.recreateCacheImage();
flowChart.add(one);
flowChart.add(two);
flowChart.add(four);
flowChart.add(five);
four.attachTo(three, AttachToNode.TopCenter);
[/code]
Resize the biggest box (the one which contains the the three boxes).
The box to the bottom right disappears.
If I remove
[code]
[/code]
the symbol stops disappearing.
Is that line really required, or can I lose it?
