We have just released Version 4.3 of Planner.NET. It contains the following customer-requested features:
~ List view replaces the old DayRange view
~ List view displays arbitrary long sequences of seconds, minutes, hours, days, weeks, months or years
~ the Position enumeration contains a None value, which indicates that headers will not be displayed
~ TimeFormat property has been added to AppointmentForm, TaskForm and RecurrenceForm
~ TimelineSettings exposes three new properties: NowColor, NowFillColor and ShowCurrentTime
~ WeekRangeHeaderStyle enumeration contains a Reference member, which indicates whether the view header should display the name of the corresponding resource when grouping is enabled
~ CurrentTime property has been added to the Calendar class; it may be used to 'override' the current system time
~ Calendar.ToolTip gives access to the underlying .NET ToolTip object associated with the control
Registered customers are going to receive their upgrades shortly. Evaluation copy can be downloaded here -
https://mindfusion.eu/PlannerTrial.zip
