Normal Topic two calendars two views (Read 3166 times)
elpuerco
Time?  What's time matta
to a pig?
Nov 27th, 2007 at 7:28am
Hi, I feel I am missing something here re the planner control and not understanding the connection and would appreciate any help on offer.
I have two calendar, one in month view and one in timetableview.
The monthview calendar is only used to select a date and display in highlight if an appoint exists on a given date.
The timetableview calendar moves to the date selected on the monthview calendar and allows the user to drag entries from a combobox onto it to create appointments.
When appointments are created or deleted the monthview calendar is updated accordingly.
The problem is that when I first open the application the timetableview calendar is correctly updated from the underlying database by way of the LoadFromDatasource() method.
But the monthview calendar does not get updated thus resulting in no higlights to show where appointments exist.
I then thought I needed of course to call the LoadFromDatasource() method of the monthview calendar but I get this error:
Item has already been added. Key in dictionary:
'MindFusion.Scheduling.Appointment'  Key being added:
Here is the code for the refresh button I use to test it:
If MessageBox.Show("Refreshing delivery schedule from database will overwrite displayed schedule, do you wish to continue.", "Confirm Refresh", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button2) = Windows.Forms.DialogResult.Yes Then
		Me.calTimeTableView.Schedule.Clear()
		Me.PlannerSQLDataSet.Reminder.Clear()
		Me.PlannerSQLDataSet.Style.Clear()
		Me.PlannerSQLDataSet.CustomBrushes.Clear()
		Me.PlannerSQLDataSet.Contact.Clear()
		Me.PlannerSQLDataSet.Location.Clear()
		Me.PlannerSQLDataSet.Resource.Clear()
		Me.PlannerSQLDataSet.Task.Clear()
		Me.PlannerSQLDataSet.Item.Clear()
		Me.PlannerSQLDataSet.ItemContacts.Clear()
		Me.PlannerSQLDataSet.ItemResources.Clear()
		Me.PlannerSQLDataSet.Recurrence.Clear()
		Me.PlannerSQLDataSet.RecurrenceException.Clear()
		Me.PlannerSQLDataSet.RecurrenceExceptions.Clear()
		Me.ReminderTableAdapter1.Fill(Me.PlannerSQLDataSet.Reminder)
		Me.StyleTableAdapter1.Fill(Me.PlannerSQLDataSet.Style)
		Me.CustomBrushesTableAdapter1.Fill(Me.PlannerSQLDataSet.CustomBrushes)
		Me.ContactTableAdapter1.Fill(Me.PlannerSQLDataSet.Contact)
		Me.LocationTableAdapter1.Fill(Me.PlannerSQLDataSet.Location)
		Me.ResourceTableAdapter1.Fill(Me.PlannerSQLDataSet.Resource)
		Me.TaskTableAdapter1.Fill(Me.PlannerSQLDataSet.Task)
		Me.ItemTableAdapter1.Fill(Me.PlannerSQLDataSet.Item)
		Me.ItemContactsTableAdapter1.Fill(Me.PlannerSQLDataSet.ItemContacts)
		Me.ItemResourcesTableAdapter1.Fill(Me.PlannerSQLDataSet.ItemResources)
		Me.RecurrenceTableAdapter1.Fill(Me.PlannerSQLDataSet.Recurrence)
		Me.RecurrenceExceptionTableAdapter1.Fill(Me.PlannerSQLDataSet.RecurrenceException)
		Me.RecurrenceExceptionsTableAdapter1.Fill(Me.PlannerSQLDataSet.RecurrenceExceptions)
		Me.calTimeTableView.LoadFromDataSource()
		Me.calMonthView.LoadFromDataSource()
		MessageBox.Show("The delivery schedule has been refreshed", "Successful Refresh", MessageBoxButtons.OK, MessageBoxIcon.Information)
	  End If
Have I totally misunderstood how these things work?
Re: two calendars two views
Reply #1 - Nov 27th, 2007 at 8:05am
If you are using the same schedule for both views, there is no need to load it twice. However, once the schedule is loaded, you have to update the Monthly view so that the appropriate dates are bold.
elpuerco
to a pig?
Reply #2 - Nov 27th, 2007 at 8:33am
Fandabbydosey Smiley  thanks Meppy  Grin
 For Each ni In Me.calTimeTableView.Schedule.Items
		    ProcessItemCreated(ni)
 Next
Leo
Reply #3 - Dec 7th, 2007 at 9:18am
Good afternoon,
I have the same error, by using a code like this:
       Dim appp As New MindFusion.Scheduling.Appointment
       Dim no As DateTime = Now
       appp.StartTime = no
       appp.EndTime = DateAdd(DateInterval.Hour, 1, no)
       appp.Subject = "Subject #1"
       appp.HeaderText = "Header #1"
       appp.DescriptionText = "Descr #1"
       Cal01.Schedule.Items.Add(appp)
       appp.StartTime = DateAdd(DateInterval.Day, 5, no)
       appp.EndTime = DateAdd(DateInterval.Hour, 5, appp.StartTime)
       appp.Subject = "Subject #2"
       appp.HeaderText = "Header #2"
       appp.DescriptionText = "Descr #2"
If I comment the second part it works fine.
Problably something is not clear to me.
Thanks in advance for any help.
Leo
Reply #4 - Dec 7th, 2007 at 9:50am
You have to create another Appointment object before the second block. Otherwise you will try to add the same appointment twice.
appp.StartTime = no
appp = New MindFusion.Scheduling.Appointment
Leo
Reply #5 - Dec 7th, 2007 at 10:50am
Wonderfull! Now it's clear.
Thank you very much.
leo
