Normal Topic Really simple/stupid save/load question (Read 2712 times)
SavyCat
Feb 18th, 2008 at 2:26pm
Hi guys, I cant seem to get this to work. I have read the manual, tried the forums and now I have to ask someone. I cant get the SaveToFile and LoadFromFile to work. I created a really simple app - but no luck. Could any one please point out whats wrong with this? It seems really simple, so its driving me mad. If there is no obvious mistake - the IDE raises a null exception on the LoadFrom(System.IO.BinaryReader reader, PersistContext ctx) function. Here is my code:
public class TestNode : ShapeNode
        public TestNode()
            : base()
        protected override void SaveTo(System.IO.BinaryWriter writer, PersistContext ctx)
            base.SaveTo(writer, ctx);
        protected override void LoadFrom(System.IO.BinaryReader reader, PersistContext ctx)
            base.LoadFrom(reader, ctx);
public partial class Form1 : Form
        public Form1()
            InitializeComponent();
            Diagram.RegisterItemClass(typeof(TestNode), "TestNode", 1);
            TestNode test = new TestNode();
            diagram1.Nodes.Add(test);
        private void button1_Click(object sender, EventArgs e)
            //A save button
            diagram1.SaveToFile("Test");
        private void button2_Click(object sender, EventArgs e)
            //A load button
            diagram1.LoadFromFile("Test");
Re: Really simple/stupid save/load question
Reply #1 - Feb 19th, 2008 at 6:35am
This looks like a bug - the ShapeNode deserialization code expects that its parent diagram should be already set. To work around that, add this constructor to TestNode
public TestNode(Diagram parent) : base(parent)
SavyCat
Reply #2 - Feb 19th, 2008 at 8:32am
Ah ha, that would why then Smiley I changed it and it worked out fine. Thanks Stoyo!
SavyCat
Reply #3 - Feb 19th, 2008 at 3:36pm
Hi Stoyo, this might be related or I might be doing it wrong; but I cant seem to get a controlNode to save or load - even if I do provide the diagram and have made sure the control has no constructor parameters. Any ideas? Thanks again Smiley
SavyCat
Reply #4 - Feb 19th, 2008 at 3:44pm
oh - forgot to say that the control is a user control with a few buttons, a list view, a checkbox and is [serialized].
Reply #5 - Feb 19th, 2008 at 4:59pm
Flowchart.NET saves automatically only the public properties of hosted controls, and only if they are of serializable types. You could handle the SerializeControl event to implement your own serialization, or just create public properties for all pieces of data that should be saved.
