Normal Topic Copy/Paste and Undo/Redo (Read 5192 times)
ciccio
Mar 3rd, 2008 at 8:44am
Can the WpfDiagram support Copy/Paste and Undo/Redo? If not did you plan to develop them? If yes when do you plan to release them?
Re: Copy/Paste and Undo/Redo
Reply #1 - Mar 3rd, 2008 at 12:18pm
There are CopyToClipboard and PasteFromClipboard methods available in the Diagram class. We have recently fixed some bugs in them, and the beta version that we uploaded on Friday should contain the fixes.
To use undo / redo, set Diagram.UndoManager.Enabled = true.
ciccio
Reply #2 - Mar 3rd, 2008 at 1:50pm
Thank you for your answer.
I set the property but when I press Ctrl+X nothing happens. Is there something else that is missing?
ciccio
Reply #3 - Mar 3rd, 2008 at 1:58pm
I created 2 command bindings and it works. I expected that it would have done it automatically Smiley
Thank you
