Normal Topic Problems with redisplay the link (Read 2464 times)
KNguyen
Mar 28th, 2008 at 3:06pm
hi,
I'm evaluating the FlowChart.Net and i have a problem redisplay the link from the stored list.
i have a testNode and testLink basically follow the basic tutorial.
here is my code:
    public class myLink: DiagramLink
  public MyLink(Diagram diagram)
: base(diagram)
  public MyLink(Diagram diagram, MyNode src, MyNode dest)
: base(diagram, src, dest)
  public MyLink(MyLink prototype, MyNode src, MyNode dest)
: base(prototype, src, dest)
  public MyLink(MyLink prototype, Diagram diagram)
: base(diagram)
  protected override void LoadFrom(System.IO.BinaryReader reader, PersistContext context)
base.LoadFrom(reader, context);
  protected override void SaveTo(System.IO.BinaryWriter writer, PersistContext context)
base.SaveTo(writer, context);
TestLink
    public class MyNode:DiagramNode
  public MyNode(Diagram diagram)
: base(diagram)
  public MyNode(MyNode prototype)
: base(prototype)
  public override void Draw(MindFusion.Drawing.IGraphics graphics, RenderOptions options)
graphics.DrawRectangle(Pens.Black, Rectangle.Truncate(this.bounds));
  public override void DrawShadow(MindFusion.Drawing.IGraphics graphics)
and i'm trying see if i can recreate the diagram from a stored List
private List<myNode> testNodes = new List<myNode> ();
       private List<myLink> testLinks = new List<myLink>();
       private void testToolStripMenuItem1_Click(object sender, EventArgs e)
           TestDiagramNode node0 = new TestDiagramNode(currentDiagram());
           TestDiagramNode node1 = new TestDiagramNode(currentDiagram());
           node0.Bounds = new RectangleF(18F, 26F, 7.2736F, 7.878159F);
           node1.Bounds = new RectangleF(62F, 26F, 6.280975F, 7.878159F);
           currentDiagram().Nodes.Add(node0);
           currentDiagram().Nodes.Add(node1);
           TestDiagramLink link = new TestDiagramLink(currentDiagram(), node0, node1);
           TestDiagramLink link2 = new TestDiagramLink(currentDiagram(), node1, node0);
           currentDiagram().Links.Add(link);
           currentDiagram().Links.Add(link2);
           testLinks.Add(link);
           testLinks.Add(link2);
           testNodes.Add(node0);
           testNodes.Add(node1);
then i try to retrieve and recreate:
  private void retrieveToolStripMenuItem_Click(object sender, EventArgs e)
           foreach (TestDiagramNode node in testNodes)
               currentDiagram().Nodes.Add(node);
           TestDiagramLink link = new TestDiagramLink(currentDiagram(),testNodes[0],testNodes[1]);
           TestDiagramLink link1 = new TestDiagramLink(currentDiagram(), testNodes[1], testNodes[0]);
           currentDiagram().Links.Add(link1);
the above work fine, the arrow origin and destination were perfect, but not this:
           TestDiagramLink link2 = new TestDiagramLink(currentDiagram());
           link2.Origin = testNodes[0];
           link2.Destination = testNodes[1];
The link's origin alway located at 0.0 (upper left corner of the diagram view) then the arrow end at the destination node, do you know why?
Re: Problems with redisplay the link
Reply #1 - Mar 28th, 2008 at 3:37pm
Hi. Are you using more than one diagrams?
KNguyen
Reply #2 - Mar 28th, 2008 at 8:11pm
yes, and my currentDiagram() return the selected diagram.
KNguyen
Reply #3 - Mar 28th, 2008 at 8:43pm
Hi stoyo,
from your last comment, i was thinking maybe multiple diagrams could be the reason for the link not to display correctly, so i created another test form with only one diagram this time, it still doesn't display the link correctly if i set the origin and destination outside of the constructor. This is driving me nut!
here is my new test code:
public partial class Form1 : Form
       public Form1()
           InitializeComponent();
           test();
       private List<MyNode> testNodes = new List<MyNode>();
       private List<MyLink> testLinks = new List<MyLink>();
       private void test()
           MyNode node0 = new MyNode(diagram1);
           MyNode node1 = new MyNode(diagram1);
       private void button1_Click(object sender, EventArgs e)
           foreach (MyNode node in testNodes)
               diagram1.Nodes.Add(node);
           //MyLink link = new MyLink(diagram1, testNodes[0], testNodes[1]);
           //diagram1.Links.Add(link);
           //TestDiagramLink link1 = new TestDiagramLink(currentDiagram(), testNodes[1], testNodes[0]);
           //currentDiagram().Links.Add(link1);
           MyLink link2 = new MyLink(diagram1);
           link2.Origin = testNodes[1];
           link2.Destination = testNodes[0];
           diagram1.Links.Add(link2);
Reply #4 - Mar 29th, 2008 at 10:18am
Calling the link's UpdateIntersections method seems to fix that:
MyLink link2 = new MyLink(diagram);
diagram.Links.Add(link2);
link2.UpdateIntersections();
diagram.Invalidate(link2.GetRepaintRect(false));
KNguyen
Reply #5 - Mar 31st, 2008 at 3:04pm
it works, thanks you.
