Normal Topic FlowChartX 4.1.5 released! (Read 1894 times)
Apr 8th, 2008 at 5:30pm
FlowChartX 4.1.5 adds the following new features:
~ Styled text in tables;
~ Improved XML format;
~ If the scrollbars are not needed because the visible region is larger than the document size, they are either hidden or disabled, as set via DisableNoScroll;
~ The RowFromPoint and ColumnFromPoint let you find which cell of a table contains the specified point;
~ More optimizations in the GDI+ graphics engine;
~ AddAnchorPointF and GetAnchorPointF methods added for a greater precision of anchor point definitions;
~ The Repaint method lets you refresh custom-drawn boxes when the data they display changes;
~ BackColor property added to the Overview class;
~ SwapPairsIterations property added to LayeredLayout;
~ Now RequestDelete* events are also raised when cutting items to the clipboard;
~ The Route method lets you run the routing algorithm for a single Arrow;
The trial version is now available for download here:
https://www.mindfusion.eu/FCXdemo.zip
https://www.mindfusion.eu/FCXdemoPro.zip
Registered customers will receive their upgrades shortly.
