Hot Topic (More than 10 Replies) CellTime controlled from UI? (Read 4515 times)
bequer
May 18th, 2008 at 4:17pm
Is there a built in manner to control the celltime value from user interface. I enabled ShowNavigationButton but it does not show any button to change the CellTime value. How can I do this?
Thanks for any help,
Bequer
Re: CellTime controlled from UI?
Reply #1 - May 19th, 2008 at 7:29am
What view are you using? The ShowNavigationButtons property only works in Timetable and List views.
bequer
Reply #2 - May 19th, 2008 at 1:22pm
I use the TimeTableView, navigation buttons work fine but there are for dates only. My point is : how can I display buttons to allow the user to change the CellTime himself: 5 min, 10 min, 15 min, 30 min, 45 min and 60 min?
Reply #3 - May 19th, 2008 at 1:40pm
I am afraid there is no built-in feature that enables interactive modification of the cell duration. You have to add another control on the form, containing the Calendar control (for example a track bar), and use this control in order to manipulate the cell spans.
bequer
Reply #4 - May 19th, 2008 at 3:39pm
Ok,
I will add two little buttons similar to the navigation buttons in the calendar header. Is there a clean manner to do it I can send you back to become a standard feature?
Reply #5 - May 20th, 2008 at 6:10am
There is no clean way of doing this I can think of. Here is a code that can be used in order to add and position two buttons in the Calendar control. Unfortunately, this code relies on alot of speculations in order to calculate the actual position of the new buttons:
foreach (Control c in calendar1.Controls)
	if (c.Visible && c is Button)
		if ((c as Button).Image != null)
			int width = c.Width;
			if (c.Left - width < 0)
				// Its the right button
				Button b = new Button();
				b.Text = "<<";
				b.Size = c.Size;
				calendar1.Controls.Add(b);
				b.Location = new Point(c.Right, c.Top);
			else
				// Its the left button
				b.Text = ">>";
				b.Size = c.Size;
				b.Anchor = AnchorStyles.Right;
				b.Location = new Point(c.Left - width, c.Top);
bequer
Reply #6 - May 20th, 2008 at 2:12pm
I added two buttons in the left top corner of the timetableview with colors closed of the windows 2003 theme.
Thks
harish_agr
Reply #7 - Mar 23rd, 2009 at 2:23pm
I want to resize the image associated with Appointment class. I have tried with ImageAlignment property to change the size of the image but not able to define the dynamic image size. Sad
I want to change my Image size based on Appointment object cell size.
Please help me.
Harish
Reply #8 - Mar 23rd, 2009 at 4:01pm
Can you please let me know which calendar view you are using?
harish_agr
Reply #9 - Mar 24th, 2009 at 4:20am
I am using Resource View and version is 4.5.x
Reply #10 - Mar 24th, 2009 at 7:22am
I have inspected the code and it seems that Style.ImageAlignment is only considered when the style is applied to a view cell rather than an item. The item image is always rendered in the left (top/left) corner of the item. However, you can create a custom item viewer in order to implement custom drawing logic for your items.
For more information on how to create custom item viewers, check Tutorial #5 in the Planner.NET documentation.
