Normal Topic How can I stop a node being dragged off screen? (Read 1345 times)
brianh
Jul 16th, 2008 at 10:44am
I need to prevent nodes from being dragged of the top or left edges of the screen, any ideas how best to handle this?
Thanks.
Brian
Re: How can I stop a node being dragged off screen
Reply #1 - Jul 16th, 2008 at 12:39pm
By default the control shouldn't let users drop items off the diagram.Bounds area. That's set through the Diagram.RestrictItemsToBounds property. If what you need is to disable auto-resizing to the left and top, set Diagram.AutoResize = RightAndDown.
brianh
Reply #2 - Jul 16th, 2008 at 12:53pm
Hi Stoyan,
My problem was that the node caption could be dragged off screen (even though some of the node was still visible), and since my nodes can only be dragged by their caption this meant that I could never drag it back on.
Changing the Diagram.RestrictItemsToBounds property to InsideOnly fixed the problem. Smiley
Thanks.
Brian
