I'm using Version 4.3.0.12335 on .Net 3.5 framework. When dealing with recurrence i get the following error when it the control redraws. Might this having anything to do with Recurrence Master? Isn't that a readonly value or do i have to manually set that?
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at MindFusion.Scheduling.Appointment.get_Style() at MindFusion.Scheduling.WinForms.ScheduleItemPainter.ProcessFillSpan(Item item, Rectangle itemRect, Boolean startsHere, Boolean endsHere) at MindFusion.Scheduling.WinForms.ScheduleItemPainter.ProcessItem(Item item, Rectangle itemRect, Boolean startsHere, Boolean endsHere, Int32 pass) at MindFusion.Scheduling.WinForms.ScheduleItemProcessor.Process(DateTime startTime, DateTime endTime, Rectangle contentsBounds, TimeSpan start, TimeSpan end, TimeSpan dayStart, TimeSpan dayEnd, Resource reference) at MindFusion.Scheduling.WinForms.ScheduleItemPainter.Process(DateTime startTime, DateTime endTime, Rectangle contentsBounds, TimeSpan start, TimeSpan end, TimeSpan dayStart, TimeSpan dayEnd, Resource reference) at MindFusion.Scheduling.WinForms.ScheduleColumnCell.Draw(DrawContext context) at MindFusion.Scheduling.WinForms.Cell.Draw(DrawContext context) at MindFusion.Scheduling.WinForms.ScheduleCell.Draw(DrawContext context) at MindFusion.Scheduling.WinForms.Calendar.OnPaint(PaintEventArgs pe) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
