Normal Topic Undo not working (Read 1102 times)
kwinovich
Undo not working
Aug 1st, 2008 at 8:14pm
I cant seem to get Undo to work properly when manipulating controlpoints via code. Code is below. Any ideas?
       private void diagram1_LinkStartModifying(object sender, LinkValidationEventArgs e)
           composite = new CompositeCmd(diagram1, "drag");
           if ((int)e.Link.Tag == 2)
               foreach (DiagramLink dl in diagram1.Links)
                   if ((int)dl.Tag == 1)
                       change = new ChangeItemCmd(dl, "Change");
                       composite.AddSubCmd(change);
       private void diagram1_LinkModified(object sender, LinkEventArgs e)
           composite.Execute();
       private void diagram1_LinkModifying(object sender, LinkValidationEventArgs e)
                       dl.ControlPoints[dl.ControlPoints.Count - 1] = e.Link.ControlPoints[0];
                       change.Execute();
                       dl.UpdateFromPoints();
                       dv.RecreateCacheImage();
       private void button7_Click(object sender, EventArgs e)
           diagram1.UndoManager.Undo();
Iva
Re: Undo not working
Reply #1 - Aug 4th, 2008 at 6:43am
Try this -
private List<ChangeItemCmd> changeCmds;
private void diagram_LinkStartModifying(object sender, LinkValidationEventArgs e)
     changeCmds = new List<ChangeItemCmd>();
           foreach (DiagramLink dl in diagram.Links)
                       ChangeItemCmd change = new ChangeItemCmd(dl, "Change");
                       changeCmds.Add(change);
private void diagram_LinkModifying(object sender, LinkValidationEventArgs e)
                       diagramView.RecreateCacheImage();
private void diagram_ActionRecorded(object sender, UndoEventArgs e)
     if (e.Command is ModifyItemCmd)
           foreach (ChangeItemCmd cmd in changeCmds)
           cmd.Execute();
Iva
