Normal Topic Layouting diagram: avoid bounds recomputing/redraw (Read 1756 times)
dku
Aug 20th, 2008 at 11:51am
I'm performing 'complex' layouting around a layered layout.
In my method, I'm removing items (myGraphicalExplorerDiagram.Items.Remove (..)) - it is changing the bounds (Autosize=default value). I'm also making other changes that probably fires recomputing and redraws.
Gives it a way to block any computing/redrawing in the diagram ? (I've tried diag.BeginInit()/EndInit() - but no success - bounds are recomputed).
Using version 1.0.
Didier
Re: Layouting diagram: avoid bounds recomputing/re
Reply #1 - Aug 20th, 2008 at 2:56pm
Set AutoResize = None before running your layout code, then enable it again and call ResizeToFitItems().
