Normal Topic Dynamic tooltip (Read 3195 times)
dku
Dynamic tooltip
Aug 27th, 2008 at 7:28am
I'm associating object with diagram items through tag property. My associated objects have all the same interface with a GetDescription method returning a string.
I want to display this description in the tooltip but I don't want to set all tooltips to diagram items.
Is that possible to be be called to provide the tooltip content dynamically ?
I've seen the GetToolTipmethod, but if possible, I don't want to override the items.
Didier
Re: Dynamic tooltip
Reply #1 - Aug 27th, 2008 at 9:50am
The WPF TooltipService displays the tooltip of a parent element when a child element doesn't provide its own tooltip. You might handle MouseMove and call
ToolTipService.SetToolTip(diagram, tagDescription);
where tagDescription is a value you get form the tag of the item under the mouse cursor, or null if there is no item under the cursor.
dku
Re: Dynamic tooltip
Reply #2 - Aug 27th, 2008 at 12:43pm
Yes, thanks.
Didier
SC
Re: Dynamic tooltip
Reply #3 - Sep 8th, 2008 at 10:42pm
I have diagramnode and shapenodes are attached to its inputs and outputs.
How can I show tooltip when I hover over the output shapenode. I couldn't find any events/methods for shapenodes.
CS
Re: Dynamic tooltip
Reply #4 - Sep 9th, 2008 at 6:53am
You could either set the ShapeNode's ToolTip, or call ToolTipService.SetToolTip(diagram, tagDescription) from the MouseMove handler depending on what node is returned by the GetNodeAt method.
