Normal Topic Conflict version about MindFusion.Common library (Read 6261 times)
alesdario
Oct 2nd, 2008 at 1:09pm
Hi stoyo.
Last year i crate a webapplication using web-version of Flowchart.NET. Now i want to add to my application an extension for generate chart starting from my database.
Webchart.net needs "MindFusion.Common library version 1.0.2608.20752" while your library for charting needs "MindFusion.Common library version 1.0.3083.21564". The problem is Webchart dos't works with the new version of Mindfusion.Common library.... is there any way to solve this problem?
Tanks.
Re: Conflict version about MindFusion.Common libra
Reply #1 - Oct 2nd, 2008 at 2:59pm
We'll have to rebuild the webchart assembly. I'll send you the updated dll when it's ready.
Reply #2 - Oct 5th, 2008 at 9:57am
You can find the download link on the private messages page. We had to make many changes in the webchart code to build it with the latest version of common.dll, but haven't tested it much. Let me know if you find any problems.
alesdario
Reply #3 - Oct 9th, 2008 at 12:29pm
Tanks
