Normal Topic Treelayout at runtime (Read 2509 times)
girivc
Oct 20th, 2008 at 6:56am
I'm creating shapenodes at runtime for parents and childs. I need to get the treeview structure at runtime without specifying the Bounds for each nodes and without specifying DiagramLink for parent and child. how do I do that?
Because If I specify bounds to each nodes, then I have to keep track of all the previous node x and y coordinates in order to place the next node.
help me out.
Re: Treelayout at runtime
Reply #1 - Oct 20th, 2008 at 8:57am
Why not use the TreeLayout class? Isn't it what you refer to in the Subject line? You will have to create the DiagramLink objects though, otherwise TreeLayout doesn't have any way to infer the parent-child relationships in your diagram. You can delete the links or make them invisible after applying the layout if you don't want them in the final diagram.
girivc
Reply #2 - Oct 20th, 2008 at 9:37am
Hi Stoyan,
Thanks, its working with DiagramLink.
how do I specify the Length for DiagramLink or the distance between the nodes?
(treelayout is taking default distance now)
Reply #3 - Oct 20th, 2008 at 10:08am
Set TreeLayout.NodeDistance and TreeLayout.LevelDistance.
girivc
Reply #4 - Oct 20th, 2008 at 10:55am
Thank You Stoyan Grin
