Normal Topic Arrange progress and Cancelling the Arrange method (Read 2329 times)
tom_w
Swimlanes made our dreams
come true :-)
Oct 20th, 2008 at 5:41pm
Hi
Our solution is likely to use several thousand nodes.  My suspicion is that this may take a little while to refresh, so I'd like to show the user the progress and also allow them to cancel the Arrange.  Are either of these tasks possible?
I'm using a FlowLayout.
Tom
Re: Arrange progress and Cancelling the Arrange me
Reply #1 - Oct 21st, 2008 at 2:15pm
FlowLayout can run incrementally by adding only one node at a time, so you might try to use this to implement progress and cancel.
tom_w
come true :-)
Reply #2 - Oct 21st, 2008 at 2:26pm
Thanks Stoyan, two questions on that:
1.  Will it be a lot slower?
2.  How would you actually do that?
Thanks for all your answers so far, much appreciated  Smiley
Reply #3 - Oct 21st, 2008 at 2:57pm
You can do this by calling FlowLayout.AddNode a lot of times, and it will be a lot slower Undecided I suppose we could add some event that the layout class would raise to let you update a progressbar or cancel it, but can't give you a definitive date when it will be available.
tom_w
come true :-)
Reply #4 - Oct 21st, 2008 at 4:02pm
Thanks Stoyan.
jholliday
Reply #5 - Nov 23rd, 2010 at 2:37am
Has there been any update on the best way to show progress to the user while drawing or laying out a large diagram?  It takes on the order of 30 seconds to update my diagram on a very fast machine.  Typically longer for most users.  I need a reliable way to provide feedback during such long operations.
Reply #6 - Nov 23rd, 2010 at 7:21am
You can assign a LayoutProgress callback to the layout's Progress property and provide feedback from there.
