Normal Topic Double click event (Read 2713 times)
tusharpateluk
Double click event
Nov 12th, 2008 at 12:01pm
Hi Stoyo,
I have handled click and double click event of Node. But, when I double click on the node click event get's fired not the double click
Is it a bug?
Re: Double click event
Reply #1 - Nov 12th, 2008 at 12:20pm
It's by design. Both get raised consecutively, but you might miss the double-clicked event if the NodeClicked handler create a new window or moves the mouse capture to a different control.
private void OnNodeClicked(object sender, NodeEventArgs e)
	ShapeNode shape = e.Node as ShapeNode;
	shape.Text = "clicked";
private void OnNodeDoubleClicked(object sender, NodeEventArgs e)
	shape.Text = "double clicked";
tusharpateluk
Reply #2 - Nov 12th, 2008 at 12:34pm
I have also handled Selected and Activate events of the node. On node activation I am setting the visiblity of the custom property control.
I understand the sequence of events for node are as follows:-
Selected
Activated
Clicked & double click
Do you think what I am doing in Activation of node is the problem and hence i am not getting double click event.
tusharpateluk
Reply #3 - Nov 12th, 2008 at 2:54pm
I have manage to fix the issue. I have removed click event and handled it in selection event.
Thanks for your help
