Normal Topic Pasting unconnected links (Read 1697 times)
lindborg
Nov 28th, 2008 at 8:27am
I have been looking on the CopyPaste sample solution provided from Mindfusion.
The sample doesn't allow copying and pasting unconnected links. Why is that when i'ts possible to draw unconnected links?
Re: Pasting unconnected links
Reply #1 - Nov 28th, 2008 at 8:42am
What version of the control are you using? The CopyPaste sample calls the public bool PasteFromClipboard (
    float dx,
    float dy,
    bool unconnectedLinks
) method, which allow pasting unconnected links. I've added diagram.AllowUnconnectedLinks = true; to the constructor and copy/paste for such links works fine from what I can see.
lindborg
Reply #2 - Nov 28th, 2008 at 8:57am
Hello Stoyo...
I used the method where the items is copied to the DiagramItemCollection called clipboard.
Reply #3 - Nov 28th, 2008 at 10:18am
This sample was created at a time when there weren't built-in clipboard methods (clipCopy was used for the Copy/Paste buttons too) , but we left it for the export selection code. Is exporting the selection what you need to use? Now you can implement this using the CopySelection and PasteSelection methods of Diagram to clone the selected items into a second Diagram, and then save that diagram into a file.
