Normal Topic Use of setExpandable(true) in my Situation (Read 3689 times)
Ashutosh
Dec 2nd, 2008 at 7:20am
Hi All,
I am Generating a flowchart of any given input source code using JDiagram .
I want to hide a part of flowchart, I have already tried
node.setExpandable(true).
But my problem is that : - After using node.setExpandable(true) when I click on some node it will shirnk the whole diagram under it. But i want that only a part of diagram to collapse on clicking that node, and the portion above and below the required portions remains the same.
For example if a block conatins loop statements . Now If one wants to show detaiiled
statemts of that loop only, and wants that remaing diagram remains the same.
I am not clear with the approach,How do I proceed. Are there any other method by
which I can achive this .
If you provide me some sample code lines, it would be more beneficial for me.
Please Guide me.
Re: Use of setExpandable(true) in my Situation
Reply #1 - Dec 2nd, 2008 at 9:56am
You could handle the TreeCollapsed event, expand the children of the collapsed node, and hide the ones you wish to remain hidden.
Ashutosh
Reply #2 - Dec 2nd, 2008 at 12:10pm
Hi , I havnt Got , what u described in the reply, Please be more elaborative.
Reply #3 - Dec 4th, 2008 at 12:16pm
We have ported the ExpandButtonAction property from the .NET version, which should help in your situation:
https://mindfusion.eu/_beta/jdiag_expand.zip
Set it to RaiseEvents, and it will stop the standard tree expand/collapse processing, and will only raise the ExpandButtonClicked event. Handle the event by calling DiagramItem.setVisible(false) for the items you need to hide.
Ashutosh
Reply #4 - Dec 9th, 2008 at 11:59am
   I have used nodeClicked() method in DiagramListener, and in this method
   i am changing setExpanded(true/false) properties of ShapeNodes, to hide respect nodes and show others.
  I am able to hide the nodes i want ,by changing there Expanded properties or setting setVisible(false),
  The problem is :- "If i am hiding the nodes , The nodes which are not hided retains there location ,
there location doesnot change accordingly."
For eg.
If there are 8 nodes in my flow chart
  I want to hide 3,4,5 nodes and want 1,2,6,7,8 nodes to be visible when I click on 2nd node,
  so 6th node should take position of  3rd node while the 3,4,5 are collapsed.
As soon as 3,4,5 are expanded 6 should retain its old location(i.e after 5).
I am able to hide the nodes but not able to change the location of 6th node to 3rd node and again adjust 6th node's position after 5th(when expanded)
Reply #5 - Dec 9th, 2008 at 2:24pm
Perhaps you should also call node.setIgnoreLayout(true) if you are using TreeLayout.
Ashutosh
Reply #6 - Dec 10th, 2008 at 6:30am
Dear Stoyo,
I am Not using Tree Layout (infect i am not using any layout) . I embedded the class which extends DiagramView into my GUI,and  which is a swing based GUI.
Please Guide me , what to do ?
Reply #7 - Dec 10th, 2008 at 10:06am
Are you asking how to move programmatically a visible node so that it occupies the position of an invisible one? That should look like:
visibleNode.setBounds(invisibleNode.getBounds());
