Normal Topic Blurry text in custom WPF node in diagram (Read 8310 times)
Frans Bouma
Jan 3rd, 2009 at 12:23pm
I'm currently testing your WpfDiagram library for our next o/r mapper designer. I ran a simple test, by showing a test form with the diagram control on it and added every entity in the project using a test custom control (which are currently very ugly, but they're for testing only Wink )
Here's a screenshot:
As you can see, the text is very blurry on some elements. I set 'SnapToDevicePixels' to true on everything.
One note: the diagram control is hosted in ElementHost on a windowsform as the UI itself is made with windows forms.
What can I do to make everything appear OK?
Here's the small code snippet to display the model in the screenshot:
#region Class Member Declarations
private Dictionary<EntityDefinition, DiagramNodeAdapter> _entityToWrapper;
#endregion
public TestModelRenderer()
	InitializeComponent();
	_entityToWrapper = new Dictionary<EntityDefinition, DiagramNodeAdapter>();
	_entityDiagram.Behavior = Behavior.Custom;
	_entityDiagram.CustomNodeType = typeof(EntityGlyph);
	_entityDiagram.AlignToGrid = false;
	_entityDiagram.SnapsToDevicePixels = true;
public void ShowModel()
	Project currentProject = ApplicationStateSingleton.GetInstance().CurrentProject;
	if(currentProject == null)
		return;
	if(_entityToWrapper.Count > 0)
		return;
	foreach(EntityDefinition entity in currentProject.EntityModel.Vertices)
		EntityGlyph glyph = new EntityGlyph();
		glyph.DataContext = entity;
		glyph.SnapsToDevicePixels = true;
		DiagramNodeAdapter adapter = new DiagramNodeAdapter(glyph);
		adapter.AutoUpdateSize = true;
		adapter.SnapsToDevicePixels = true;
		_entityToWrapper.Add(entity, adapter);
		_entityDiagram.Nodes.Add(adapter);
	foreach(RelationshipEdge edge in currentProject.EntityModel.Edges)
		DiagramLink link = new DiagramLink(_entityDiagram, _entityToWrapper[edge.StartVertex], _entityToWrapper[edge.EndVertex]);
		_entityDiagram.Links.Add(link);
		link.SnapsToDevicePixels = true;
		link.SnapToNodeBorder = true;
	AnnealLayout layout = new AnnealLayout();
	layout.Arrange(_entityDiagram);
LLBLGen Pro lead developer. C# MVP
Re: Blurry text in custom WPF node in diagram
Reply #1 - Jan 5th, 2009 at 9:28am
Apparently that's a widespread problem:
http://social.msdn.microsoft.com/Forums/en-US/wpf/thread/5289ee56-6d06-4f66-84f2...
As a work-around you might try setting the diagram's SnapToDevicePixels property as well, setting such a GridSize that the grid points are aligned to device pixels, and then aligning all nodes to the grid.
Frans Bouma
Reply #2 - Jan 5th, 2009 at 9:46am
Stoyo wrote on Jan 5th, 2009 at 9:28am:
Thanks I'll try that.
One note: I tried to add normal ShapeNode instances with the name of the entity as well to the diagram and they are always sharp and non-blurry. Also when I disable snap to grid it doesn't matter. It looks like the Diagram item wrapper is aligned to a device pixel but the contents isn't.
Frans Bouma
Reply #3 - Jan 5th, 2009 at 10:13am
I saw I had not always SnapToDevicePixels added to all elements in my test Xaml, and when I added that, the elements rendered sharp.
Until I collapsed the Expander, then the collapsed element was blurry as hell.
What I wonder is: in all your demos of the WpfDiagram control, you don't have blurry text once, also not with the HTML-like elements. It's of course unacceptable for us to have blurry elements on the diagram, but as your demos never show blurryness, I wonder where the error might be, as it IS possible (your demos show that Smiley).
I read the thread, and I agree, it's the main reason why we opted for yet another Winforms based main UI, however for diagramming, Wpf seems easier, at least, at first, however it more and more starts to become a true pain as well...
I've specified my (modified test) xaml below.
<UserControl x:Class="SD.LLBLGen.Pro.Gui.Controls.WPF.EntityGlyph"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
	xmlns:c="clr-namespace:SD.LLBLGen.Pro.ApplicationCore.EntityModel;assembly=SD.LLBLGen.Pro.ApplicationCore"
    Width="150" SnapsToDevicePixels="True" Focusable="True" Height="Auto">
	<UserControl.Resources>
		<DataTemplate x:Key="itemTemplate">
			<TextBlock Text="{Binding Path=Name}" FontSize="10" SnapsToDevicePixels="True"/>
		</DataTemplate>
	</UserControl.Resources>
	<Border BorderBrush="Black" BorderThickness="0.5" CornerRadius="10" Padding="5" SnapsToDevicePixels="True">
		<Border.BitmapEffect>
			<DropShadowBitmapEffect Softness="0.355"/>
		</Border.BitmapEffect>
		<Border.Background>
			<LinearGradientBrush EndPoint="0.5,1" StartPoint="0.5,0">
				<GradientStop Color="#FFFDEEEE" Offset="1"/>
				<GradientStop Color="#FFF90909" Offset="0"/>
			</LinearGradientBrush>
		</Border.Background>
		<StackPanel Height="Auto" Width="Auto" SnapsToDevicePixels="True">
			<Label VerticalAlignment="Top" Height="Auto" Width="Auto" Content="{Binding Path=Name}" x:Name="_nameLabel" FontWeight="Bold"
			   FontSize="16" FontFamily="Tahoma" HorizontalContentAlignment="Center" Foreground="#FFFDEEEE" SnapsToDevicePixels="True"/>
			<Expander x:Name="_fieldExpander" Height="Auto" Width="Auto" Header="Fields" IsExpanded="True" SnapsToDevicePixels="True">
				<ListBox x:Name="_fieldsListBox" ItemsSource="{Binding Path=Fields}" BorderThickness="0">
					<ListBox.ItemTemplate>
						<DataTemplate>
							<TextBlock Text="{Binding Path=Name}"/>
						</DataTemplate>
					</ListBox.ItemTemplate>
				</ListBox>
			</Expander>
		</StackPanel>
	</Border>
</UserControl>
(updated the xaml a bit, it contained a lot of left-over crap from tests).
Even with a fixed width, it becomes blurry when collapsing the expander. It seems the element is rendered 1-2 pixels left of where it was. As your diagram does the positioning, I'm not sure if this is due to some wrapping code in the diagram item wrrapper.
Reply #4 - Jan 5th, 2009 at 10:29am
We don't do anything special when rendering the ShapeNodes' text, but just call DrawingContext.DrawText(nodeCenter). I suppose this might be aligned to pixels if the ShapeNode is initially created at integer coordinates and has an integer size. In your case there might be some alignment error accumulated through the layout process of the items in the control' visual tree. So instead of using the WPF built-in layout panels, you might try creating your own panel that always places its elements at integer coordinates.
Frans Bouma
Reply #5 - Jan 5th, 2009 at 11:24am
Stoyo wrote on Jan 5th, 2009 at 10:29am:
Hmm....
I think that might result in a lot of work, as expanders, listboxes and the like also likely will not make things work properly. :/
I look for a library which actually makes us write less code but if I still have to write out all the low-level rendering code, it's not worth the trouble nor the money.
I found some pixelsnapper code on an msdn blog, one variant didn't work the other one was simply very slow and also not really solving the mess. I ran into a topic about guidelines which should be used with a drawingcontext, but as I just supply a xaml object I don't see how I need to use them.
Your library was one of my last hopes of getting this done. As it seems you also don't know the answer, I guess we have to drop your library from our (now very short) list of libraries to use in our next version of LLBLGen Pro.
Reply #6 - Jan 5th, 2009 at 11:49am
You could implement something similar using TableNodes with Row.Header = true set for some rows. Though that allows only for a two-level hierarchy.
