Normal Topic DiagramView.OnMouseDown crashes in Vista (Read 4561 times)
Oskar
I like YaBB 1G - SP1!
Jan 26th, 2009 at 11:34am
We have an application with a DiagramView and it works perfectly on xp clients but on Vista clients the following exception is thrown as soon as you click in the diagram.
System.AccessViolationException: Attempt to read or write protected memory. This is often an indication that other memory is corrupt.
at MindFusion.Diagramming.WinForms.DiagramView.EndEdit(Boolean accept)
at MindFusion.Diagramming.WinForms.DiagramView.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Re: DiagramView.OnMouseDown crashes in Vista
Reply #1 - Jan 26th, 2009 at 1:58pm
Does it happen after an inplace edit operation?
Oskar
Reply #2 - Jan 27th, 2009 at 8:12am
No, it happens right from the start.
We are running version 5.1.1.21015 of the Diagramming.WinForms dll, but I tried downgrading to version 5.1.1.19447 and then the problem disappeared.
Reply #3 - Jan 27th, 2009 at 9:01am
5.1.1.21015 is what we sent you for the KeepRatio update? Could you check if the same happens with the 21375 build we sent you for the SnapToNodeBorder extension:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=122821630...
Oskar
Reply #4 - Jan 27th, 2009 at 9:19am
Could you send that version again to me? lindborg is not at the office today.
Reply #5 - Jan 27th, 2009 at 10:05am
check the PM page.
Oskar
Reply #6 - Jan 27th, 2009 at 10:36am
That solved the problem. Thank you.
