Hot Topic (More than 10 Replies) Textformatting (Read 4768 times)
lindborg
Textformatting
Jan 30th, 2009 at 2:38pm
I am using a RtfBox for inplace editing. In this rtfbox I can set parts of the text to bold, inlined and so on.
But how can I get this formatting to appear on a shape.
Re: Textformatting
Reply #1 - Jan 30th, 2009 at 4:14pm
Set EnableStyledText for the shape and use html tags to format the text. There are only a few formatting tags supported at this time; check the help file for details.
lindborg
Re: Textformatting
Reply #2 - Feb 3rd, 2009 at 8:49am
I have set the EnableStyledText . And it worked.
Now I have another problem though,
As I said earlier, I have a RichTextBox as my inplace editor. I have no problem to get the formatted text to appear on the shape but the problem is when I try to edit the formatted text again. Then the formattings is gone
When I debug the Diagram_CreateEditControl even I can see that The richtextbox has the formatting in its RTF property. But no formatting is shown in the inplaceeditor control.
Re: Textformatting
Reply #3 - Feb 3rd, 2009 at 9:10am
Are you directly assigning RichTextBox.Rtf = ShapeNode.Text?
lindborg
Re: Textformatting
Reply #4 - Feb 3rd, 2009 at 9:29am
I've tried that but then the textbox show the rtf code like
{\rtf1\ansi\ansicpg1252\deff0\deflang1053{\fonttbl{\f0\fnil\fcharset0 Microsoft Sans Serif;}}
\viewkind4\uc1\pard\b\f0\fs17 Bold\b0  tesst\par
\par
Re: Textformatting
Reply #5 - Feb 3rd, 2009 at 10:40am
Seems you will have to convert between the Flowchart.NET's HTML formatting tags and the RichtextBox RTF codes when assigning text from the one control to the other.
lindborg
Re: Textformatting
Reply #6 - Feb 3rd, 2009 at 2:02pm
I am doing that already, the conversion works fine.
I have tested the rtfstring and it validates.
Re: Textformatting
Reply #7 - Feb 3rd, 2009 at 2:06pm
Are you setting RichTextBox.Text or RichTextBox.Rtf?
lindborg
Re: Textformatting
Reply #8 - Feb 3rd, 2009 at 2:11pm
This is how my CreateEditControl event looks like
void Diagram_CreateEditControl(object sender,InPlaceEditEventArgs e) {
if(e.Node is ShapeNode) {
            //editor = new InplaceEditor();
                editor = new RichTextBox();
                e.EditControl = editor;
editor.Click += new EventHandler(Editor_Click);
editor.MouseHover += new EventHandler(Editor_MouseHover);
String text = e.Item.GetTextToEdit();
e.Item.SetEditedText("");
RectangleF docRect = e.Item.GetEditRect(PointF.Empty);
editor.Bounds = diagramView1.DocToClient(docRect);
editor.Visible = true;
    editor.Rtf = "{\\rtf1\\ansi\\ansicpg1252\\deff0\\deflang1053{\\fonttbl{\\f0\\fnil\\fcharset0 microsoft sans serif;}{\\f1\\fnil\\fcharset0 Microsoft Sans Serif;}}\r\n{\\colortbl ;\\red0\\green0\\blue0;}\r\n\\viewkind4\\uc1\\pard\\cf1\\b\\f0\\fs10 Bold \\b0\\i italics \\ul\\i0 underlined\\cf0\\ulnone\\f1\\fs17\\par\r\n}\r\n";
editor.ContextMenuStrip = contextMenuStrip2;
Editing = true;
When the editcontrol displays the text the formatting is gone.
Re: Textformatting
Reply #9 - Feb 4th, 2009 at 11:18am
This code worked fine in my test, just without the lines that attach event handlers.
MUDO
Re: Textformatting
Reply #10 - Jun 10th, 2009 at 11:39pm
Hi guys!
Which editor do you use? RichTextBox? Because if I use it as inplace editor for editing shapes text there is only area for text without any icons or whatever... How do you set bold/italic...? Via code? Maybe im blind and I dont know to use RichTextBox Sad
So how can I edit RTF text without any 3rd part solutions (DevExpress,...) or without using code solution?
Thx.
...MUDO...
Re: Textformatting
Reply #11 - Jun 11th, 2009 at 5:01am
Check the RichEdit control used in the control-hosting steps in the demo.
MUDO
Re: Textformatting
Reply #12 - Jun 11th, 2009 at 6:08am
Hi Stoyo!
But I didnt find any RTF control with panel/buttons which I need. Only that one which I described above. Could you pls state concrete example from demo browser + screen?
Thx.
...MUDO...
Re: Textformatting
Reply #13 - Jun 11th, 2009 at 10:54am
There is a user control in RichEdit.cs in the Demo example; it has a toolbar and a rich-edit control inside. You can see it used in the Control Hosting -> Control Diagram page. The toolbar is displayed only when the control is on focus.
MUDO
Re: Textformatting
Reply #14 - Jun 11th, 2009 at 3:07pm
Hi!
Thx Stoyo, I was checking Samples Smiley Yes I found it in Demo now so thank you.
...MUDO...
