Normal Topic Diagram constructor failure on server side (Read 4032 times)
jaiswalamit
Feb 17th, 2009 at 11:57am
Hi I am evaluating DiagramLite for silverlight. I need to build the nodes of the diagram on server side code (asp.net and assemblies). So I want to create the Diagram object on server and use SaveToXml(stream) to get the tream and then use the stream on the silverlight client where I want to use LoadFromXML()
I have used the DiagramLite dll on the server side also. So I am able to compile but at run time the constructor fails:
Diagram diagram = new Diagram();
The type initializer for 'MindFusion.Diagramming.Silverlight.Brushes' threw an exception. at MindFusion.Diagramming.Silverlight.Diagram..ctor()
Any help will be appreciated.
Amit
Re: Diagram constructor failure on server side
Reply #1 - Feb 17th, 2009 at 12:07pm
I don't think you can load DiagramLite.dll on its own, without the Silverlight runtime and plugin. Instead, on the server side create a Diagram instance from the MindFusion.Diagramming.dll, found in the packages below:
https://www.mindfusion.eu/NetDiagramTrial.zip
jaiswalamit
Reply #2 - Feb 17th, 2009 at 12:17pm
Hmm ok so I need to use a separate component on the server side- make sense.
Just wondering if we would have to purchase these (any one)  products as well?
Thanks a lot for the prompt response.
Best Regards!
Reply #3 - Feb 17th, 2009 at 12:24pm
You'd not have to purchase them if just for creating and serializing a Diagram object.
PS. The upcoming NetDiagram release has a Silverlight frontend based on Diagramlite.dll.
