Normal Topic Zoom on FlowCharter Diagram View (Read 5279 times)
SandeepGowda
Feb 23rd, 2009 at 7:26am
Hi
  Can we have A Zoom on FlowCharter/TaskShape Nodes.
Regards
Sandeep
Re: Zoom on FlowCharter Diagram View
Reply #1 - Feb 23rd, 2009 at 9:03am
Hi Sandeep,
You could call DiagramView.ZoomToRect(node.Bounds).
SandeepGowda
Reply #2 - Feb 23rd, 2009 at 10:58am
hi,
m_mainJDiagramView(diagram instance).zoomToFit(new Rectangle2D.Double(50,50,50,50));
i tried by using above code, its not working. can you please help me if i am wrong.
regards
sandeep
Reply #3 - Feb 23rd, 2009 at 11:33am
So you are using our JDiagram control? Have you placed the DiagramView inside a JScrollPane? - I think that's required for the scroll, zoomtorect and bringIntoView methods to work.
SandeepGowda
Reply #4 - Feb 23rd, 2009 at 12:09pm
hi,
Code snippet:
// holds Jdiagram.
JideScrollPane jideJdiagramScrollPane = new JideScrollPane();
jideJdiagramScrollPane.getViewport().add(m_mainJDiagramView);
i have added as above,still not working
regards
sandeep
Reply #5 - Feb 23rd, 2009 at 12:13pm
Does JideScrollPane derive from JScrollPane?
SandeepGowda
Reply #6 - Feb 23rd, 2009 at 12:45pm
Yes,
regards
sandeep
Reply #7 - Feb 23rd, 2009 at 1:16pm
Is the JideScrollPane class from this package?
http://www.jidesoft.com/products/oss.htm
Reply #8 - Feb 23rd, 2009 at 3:33pm
We have tried that JideScrollPane and zoomToRect worked as expected. Could you email us a sample project that shows your problem?
