Normal Topic Zoom on Scroll of a Mouse (Read 4411 times)
SandeepGowda
Feb 25th, 2009 at 9:31am
Can we apply Zoom on Scroll of a Mouse for Diagram view.
regards
sandeep.
Re: Zoom on Scroll of a Mouse
Reply #1 - Feb 25th, 2009 at 11:07am
You could handle the MouseWheel event as shown here:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=122542302...
SandeepGowda
Reply #2 - Feb 25th, 2009 at 1:00pm
Do i need to add Mouse wheel action listener to Diagram View.
Can you please help me in Java base code.
Regards
Sandeep
Reply #3 - Feb 25th, 2009 at 1:17pm
Yes, you should add a MouseWheelListener to the view and implement its method. Please post in the JDiagram board; I'm moving this there.
SandeepGowda
Reply #4 - Feb 25th, 2009 at 1:45pm
hi,
form is new to me, how can post Jdiagram Board?.
Can you please help me in to Change to Java code.
Point p = m_mainJDiagramView.docToDevice(evt.getPoint());
Point oldcurpos = m_mainJDiagramView.docToDevice(p);
//no idea about ZoomFactor,hw will i get?
m_mainJDiagramView.ZoomFactor += e.Delta / 60f;
//what is Delta??
Point newcurpos = m_mainJDiagramView.ClientToDoc(m_mainJDiagramView.PointToClient(Cursor.Position)
float diffx = (oldcurpos.X - newcurpos.X);
float diffy = (oldcurpos.Y - newcurpos.Y);
m_mainJDiagramView.ScrollTo(
m_mainJDiagramView.ScrollX + diffx < 0 ? 0 : m_mainJDiagramView.ScrollX + diffx,
m_mainJDiagramView.ScrollY + diffy < 0 ? 0 : m_mainJDiagramView.ScrollY + diffy);
regards
sandeep
Reply #5 - Feb 25th, 2009 at 3:11pm
Bookmark this page and use the Start New Topic link from the bottom right:
http://mindfusion.eu/Forum/YaBB.pl?board=jdiag_disc
Handling the mouse wheel event should look like this:
diagramView.addMouseWheelListener(new MouseWheelListener()
	public void mouseWheelMoved(MouseWheelEvent e)
		diagramView.setZoomFactor(diagramView.getZoomFactor() + e.getWheelRotation() / 2);
SandeepGowda
Reply #6 - Feb 26th, 2009 at 6:20am
hi,
i tried with below java code, but its not working,can you please help if i am wrong,
public void mouseWheelMoved(MouseWheelEvent evt) {
// evt.
Point2D boxDevPos = new Point(evt.getX(), evt.getY());
// Point2D.Float boxDocPos = m_mainJDiagramView.deviceToDoc(boxDevPos);
Point boxDocPos = m_mainJDiagramView.docToDevice(boxDevPos);
m_mainJDiagramView.setZoomFactor(m_mainJDiagramView.getZoomFactor()
+ evt.getWheelRotation() / 2);
Point2D afterZoom = m_mainJDiagramView.deviceToDoc(boxDocPos);
m_mainJDiagramView.setScrollX((float) (m_mainJDiagramView.getScrollX()
- boxDevPos.getX() + afterZoom.getX()));
m_mainJDiagramView.setScrollY((float) (m_mainJDiagramView.getScrollY()
- boxDevPos.getY() + afterZoom.getY()));
regards
sandeep
