Normal Topic Problem exporting to PDF (something related with c (Read 1774 times)
vtortola
Mar 5th, 2009 at 1:10pm
When I try to export to PDF one of our diagrams I get the following exception when I call PdfExporter.Export():
System.ArgumentException occurred
Message="Property must be set to a valid ColorBlend object to use interpolation colors. ColorBlend objects must be constructed with the same number of positions and color values. Positions must be between 0.0 and 1.0, 1.0 indicating the last element in the array."
Source="System.Drawing"
StackTrace:
at System.Drawing.Drawing2D.LinearGradientBrush._GetInterpolationColors()
InnerException:
Any idea about which the problem is?
Cheers.
Re: Problem exporting to PDF (something related wi
Reply #1 - Mar 5th, 2009 at 6:08pm
Could you save and email the diagram to support@mindfusion.eu?
vtortola
Reply #2 - Mar 6th, 2009 at 5:45pm
hum... ok, i'll try it and I'll send it by email.
