Normal Topic attching a node to mouse pointer ? (Read 1941 times)
jay
Mar 9th, 2009 at 5:09am
Hi Stoyo,
            whether it would be possible to attach a node to mouse pointer on certain event , and when user clicks on graph area node should be placed to that  part of graph.
Thank you
Re: attching a node to mouse pointer ?
Reply #1 - Mar 9th, 2009 at 9:33am
Hi Jay,
You could create a node in response to that event, set some boolean field to true, and in the mouseMove handler move the node to the pointer position if the boolean flag is enabled. In the click handler just set the flag back to false.
jay
Reply #2 - Mar 9th, 2009 at 9:49am
Hi stoyo,
             Thank you for reply, idea is good, it would work.
