Normal Topic how to get all the nodes on graph ? (Read 2229 times)
jay
Mar 9th, 2009 at 10:53am
Hi stoyo,
            I have created various nodes on graph,some are connected, some nodes in the graph are not connected, some do not have out links. etc.
           Now i want to check which nodes in the graph are not connected, which are not having out links. For this purpose i need all the nodes present in the graph.
But I did not find any thing to get all the nodes present in graph.
How can I iterate through all the nodes present in graph.
Thank you.
jay
Re: how to get all the nodes on graph ?
Reply #1 - Mar 9th, 2009 at 12:28pm
    Routing all the graph nodes from root could be achieved but it would work for connected nodes only,
but for getting all the connected and unconnected node of graph, i did not find any method in API.
Thank you..
Reply #2 - Mar 9th, 2009 at 2:30pm
Hi Jay,
for (DiagramNode node : diagram.getNodes())
     if (node.getIncomingLinks().size() == 0 &&
           node.getOutgoingLinks().size() == 0)
           // unconnected node
jay
Reply #3 - Mar 10th, 2009 at 6:09am
Hi stoyo,
            Thank you, it worked for me.
