Normal Topic Saving ControlNode (Read 1884 times)
castefani
Saving ControlNode
Mar 10th, 2009 at 8:40pm
I created a ControlNode:
            ControlNode n = new ControlNode (diagram, new Controls.CtlCircle ());
            n.Bounds = new rect (100, 100, 50, 50);
            diagram.Nodes.Add (n);
In diagram.SaveToString (SaveToStringFormat.Xml) occurs the following error:
      "The given key was not present in the dictionary."
Another question:
What direrença between SaveToStringFormat.Xml and SaveToStringFormat.Base64?
Re: Saving ControlNode
Reply #1 - Mar 19th, 2009 at 12:04pm
Unfortunately it’s not possible to implement automatic serialization for hosted controls. Version 1.0.2 adds a SerializeControl and DeserializeControl event you could handle to implement custom serialization for the user control properties you need to save. You ca try this with the v1.0.2 beta here:
https://mindfusion.eu/_beta/DiagramLite102.zip
This should also fix the clipping issue from your previous post.
