Normal Topic Scrollbar visibility issue (Read 2380 times)
anurodhora
Mar 12th, 2009 at 12:43pm
I have placed following code in my application:
	  <d:Ruler ScrollViewer.HorizontalScrollBarVisibility="Auto" >
		<d:Diagram ScrollViewer.HorizontalScrollBarVisibility="Auto" >
		</d:Diagram>
	  </d:Ruler>
My intention is to auto hide the horizontal scrollbar if it is in disabled state but the above code is not working as i can see the disable horizontal scrollbar.
What i am missing here? Any suggestions.
Anurodh
Re: Scrollbar visibility issue
Reply #1 - Mar 12th, 2009 at 3:12pm
https://mindfusion.eu/_beta/wpfdiag_ruler.zip
This version will let you use the <d:Ruler ScrollViewer.HorizontalScrollBarVisibility="Auto" > syntax.
anurodhora
Reply #2 - Mar 13th, 2009 at 4:51am
Thanks for the reply.
When can we get a new version that addresses the following:
1) Ruler HorizontalScrollBarVisibility
2) Pan property
3) Clip image
For all of this you have given separate versions as zip.
Thanks in advance,
Anurodh
Reply #3 - Mar 13th, 2009 at 7:14am
That last zip contains all three enhancements.
anurodhora
Reply #4 - Mar 13th, 2009 at 9:55am
