Normal Topic Node movement requirement (Read 2449 times)
anurodhora
Mar 23rd, 2009 at 12:08pm
We have a node movement requirement like:
"We want to be able to move the node just by moving the mouse cursor on the node and dragging it to some other position. Right now what is happening is that we need to first select the node and then we would be able to move it, so it requires first a click and then mouse movement."
How to achieve above requirement.
Anurodh
Re: Node movement requirement
Reply #1 - Mar 23rd, 2009 at 12:49pm
Set ModificationStart = AutoHandles.
anurodhora
Reply #2 - Mar 25th, 2009 at 11:48am
Hi Stoyo,
Thanks for the reply.
We tried this and it is working fine but we have one issue now on mouseover nodes/links looks like selected we want this feature only when we drag node.
and we do not want mouseover selection. Please suggest.
Anurodh
Reply #3 - Mar 25th, 2009 at 3:06pm
You will have to use a custom BehaviorBase derived object. Return new InteractionState(node, Action.Modify, 8) from StartDraw when some node contains the point specified as argument.
anurodhora
Reply #4 - Mar 27th, 2009 at 7:20am
Thanks Stoyo,
A lot of time i get the suggestion to use custom BehaviorBase derived object, however i am not finding myself comfortable with it so could you please share some sample code in regard to the above requirement and that will also eventually help me to get handle on using custom behavior classes.
Anurodh
« Last Edit: Mar 27th, 2009 at 11:55am by anurodhora »
Reply #5 - Mar 27th, 2009 at 2:22pm
Set ModificationStart back to SelectedOnly, and use custom behavior class like the one shown here -
http://mindfusion.eu/Forum/YaBB.pl?board=diaglite_disc;action=display;num=123566...
