Normal Topic About the edit function of the Diagram (Read 2004 times)
ragnarok00
Apr 13th, 2009 at 7:19am
I have the following question about the code. T^T
private void onEditUndo(ActionEvent e)
_flowChart.getUndoManager().undo();
private void onEditRedo(ActionEvent e)
_flowChart.getUndoManager().redo();
I have the above coding for undo and redo functions, but they don't work, how can I solve this problem?
Besides, I have written some code for Cut, Copy, and Paste function, but I am not sure whether they are correct and cannot paste the object I copied for more than one time by using the paste function.
Here is the code:
private void onEditCut(ActionEvent e)
sel = _flowChart.copySelection(_flowChart, false, true);
_flowChart.getActiveItem().setVisible(false);
private void onEditCopy(ActionEvent e)
private void onEditPaste(ActionEvent e)
CompositeCmd cmd = new CompositeCmd(_flowChart, "copied");
_flowChart.pasteSelection(_flowChart, sel, cmd, 10, 10);
Thanks. ^^
Re: About the edit function of the Diagram
Reply #1 - Apr 13th, 2009 at 9:07am
Call UndoManager.setUndoEnabled() to enable undo/redo. Use the copyToClipboard and pasteFromClipboard methods of DiagramView to implement clipboard support. You should use a larger offset values for each paste() call to make sure newly pasted items do not overlap the ones pasted previously.
ragnarok00
Reply #2 - Apr 13th, 2009 at 10:45am
It works. Thanks a lot. >3<
