Normal Topic Requires MousePosition relative to Diagram (Read 3171 times)
Bala
May 9th, 2009 at 12:29pm
I want to get mouse position with respect to the diagram when I clicked on the diagram.
Currently we are getting point from Point point = e.MousePosition; while diagram_Clicked.
Our diagram is inside a scroll viewer and we want mouse position relative to diagram not to the screen.
Bala
Re: Requires MousePosition relative to Diagram
Reply #1 - May 10th, 2009 at 9:23am
In Diagram.Clicked handler e.MousePosition already gives you the mouse position with respect to the diagram.
Bala
Reply #2 - May 11th, 2009 at 5:25am
Hi Stoyo,
Thanks for the reply, but the mouse position we are getting on diagram clicked comes out to be negative values but when we create a node at same position and on node created if we see its bounds say TopLeft the x,y position is different and we want the node created one x,y position.
please suggest something on this.
Bala
Reply #3 - May 11th, 2009 at 8:22am
Please email your test project showing this to support@mindfusion.eu.
Reply #4 - May 12th, 2009 at 1:52pm
In your email you say Quote:
1. First draw a Shape just by sketching,it will show a Message Box for x
and y position
but this does not happen. I replaced the Debug.WriteLine("node created") line in the NodeCreated handler with Debug.WriteLine(e1.Node.Bounds.TopLeft.ToString()), and then the coordinates shown when I click near the top left corner of the node are the same as the ones shown from NodeCreated. Btw in the messagebox you print a hyphen between the (x,y) string and the coordinates, maybe that's why you think they are negative?
