Normal Topic DiagramLite 1.0.3 has been released! (Read 1414 times)
May 21st, 2009 at 12:28pm
We have released version 1.0.3 of DiagramLite. It contains the following features:
~ Orthogonal graph layout algorithm
~ Circular graph layout algorithm
~ ContainerNodes can contain child nodes
~ PathFinder lets you find paths and cycles in the diagram graph
~ the Locked property lets you disable interaction with a diagram item
~ Obstacle specifies if a node is considered by auto-routed links
~ now it is possible to resize multiple items
~ HitTestPriority specifies the priority of items when hit-testing
~ AllowUnconnectedLinks lets you prevent users from drawing unconnected links
~ ImageResourceLocation and ImageWebLocation properties
~ HandlesStyle lets you change the type of nodes' adjustment handles
~ the ContainsPoint method can be used to hit-test items
~ DashStyles provides several predefined dash styles for the Pen class
~ ExpandButtonPosition and ExpandButtonBrush properties
~ AllowIncomingLinks and AllowOutgoingLinks properties
Registered customers with an active upgrade subscription will receive their upgrades shortly.
https://www.mindfusion.eu/DiagramLiteTrial.zip
