Normal Topic Get the data from all ShapeNode's and Links (Read 2893 times)
Rasmus
Jun 12th, 2009 at 6:00pm
Hallo.
I need the data from all ShapeNodes and Links which are on a diagramView.
I need it to save the data in a sql-database.
Thank for help.
regards
Rasmus
Re: Get the data from all ShapeNode's and Links
Reply #1 - Jun 12th, 2009 at 6:22pm
You can do that by iterating the diagram's Nodes and Links collections.
foreach (ShapeNode node in diagramView.Diagram.Nodes)
  string s = node.Text;
  int id = (int)node.Tag;
  // populate dataset record
You can find some code that reads from a database here:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=122477128...
I suppose writing should look similar. Let me know if you need an example.
Rasmus
Reply #2 - Jun 12th, 2009 at 8:00pm
Hallo.
Thank you.
Now I get the informations from the nodes and links.
But how I get the informations which nodes are connected with a link? So, from which node to witch note goes a link?
Read out and write in a SQL-database is not the problem.
Rasmus
Reply #3 - Jun 14th, 2009 at 9:36am
Given a link, you can get the nodes it connects by checking the link's Origin and Destination properties. Given a node, you can find the links incident to it through the node's OutgoingLinks and IncomingLinks collections.
Rasmus
Reply #4 - Jun 17th, 2009 at 12:01pm
Hallo.
Sorry, but I don't finde the right object. Embarrassed
I read the positions and texts from the nodes.
listBox1.Items.Clear();
int number= 0;
  listBox1.Items.Add("");
  listBox1.Items.Add(number.ToString());
  listBox1.Items.Add(s);
  s = "x = " + node.Bounds.X.ToString() +
        "y = " + node.Bounds.Y.ToString();
  number++;
Than I read the links:
foreach (DiagramLink Link in diagramView.Diagram.Links)
  string s = Link.Text;
But I don't finde the commands to get the information from which node to witch node the link goes. Neither about the Origin and Destination properties nor about the OutgoingLinks or IncomingLinks.
Have anybody a little code for me? ???
Regards
Rasmus
Reply #5 - Jun 17th, 2009 at 12:38pm
Origin and Destination are properties of DiagramLink:
	string o = Link.Origin.ZIndex.ToString();
	listBox1.Items.Add(o);
	string d = Link.Destination.ZIndex.ToString();
	listBox1.Items.Add(d);
OutgoingLinks and IncomingLinks are properties of DiagramNode.
Rasmus
Reply #6 - Jun 17th, 2009 at 2:37pm
Thanks a lot!  Cheesy
It's so easy and I have not see it! Sorry.
Regards
Rasmus
