Normal Topic How can i get origen/destination table node index (Read 2060 times)
roberto.bonilla
I'm so Happy
Jun 17th, 2009 at 4:13am
I have 2 tablenode in the diagram, but in the event
doc_LinkCreated i get the origen row and destination row
Dim ori As Integer = e.Link.OriginIndex
Dim des As Integer = e.Link.DestinationIndex
But the question is
How can get i the same event the value of each row in each table node
i need get the the value of row 0 of table 1 and row 1 of table 2
|Table1 | |table2 |
|row 0 |<--+ |row 0 |
|row 1 | |-->|row 1 |
thanks in advance
RB
RB
Re: How can i get origen/destination table node in
Reply #1 - Jun 17th, 2009 at 5:16am
If you know the row index, you can access the corresponding Row object through the TableNode.Rows collection. To get some cell in the row, use the indexer property (Item in VB.NET):
string cellText = table[0,row].Text;
roberto.bonilla
I'm so Happy
Reply #2 - Jun 17th, 2009 at 12:22pm
Stoyan,
thanks for the quick Answer
but my problem is how can get the origen table index and the destination table index for get the cells value origen and destination
dim tbl_orig as TableNode
dim tbl_des as TableNode
Dim rowori As Integer = e.Link.OriginIndex
Dim rowdes As Integer = e.Link.DestinationIndex
tbl_orig = doc.Nodes(????) <-- How get index
tbl_des = doc.Nodes(????) <-- how get index
dim cellori as string = tbl_orig(0,rowori)
dim celldes as string = tbl_des(0,rowdes)
??? ??? Embarrassed Undecided
RB
Reply #3 - Jun 17th, 2009 at 12:42pm
You do not need an index, you can access the tables directly using the links' Origin and Destination properties:
dim origin as TableNode = CType(e.Link.Origin, TableNode)
dim destination as TableNode = CType(e.Link.Destination, TableNode)
roberto.bonilla
I'm so Happy
Reply #4 - Jun 17th, 2009 at 1:13pm
Grin Grin Grin Wink
Thanks Very much....  Grin
great, works perfect!!!
Grin
RB
