Normal Topic Custom AnchorPoint drawing and Shape (Read 1360 times)
ilafon
Jun 19th, 2009 at 2:22am
I'm drawing custom AnchorPoints (MarkStyle = Custom && hooking on the DrawAnchorPoint event).
I'd like to use one of prefedined Shape for my AnchorPoint. But it seems that Shape objects can only be used with ShapeNode. There is no drawing method in the Shape class definition.
Is there a way to use a Shape object for AnchorPoint drawing, other than writing my own shape drawing code?
Thanks in advance for the information.
Isabelle.
Re: Custom AnchorPoint drawing and Shape
Reply #1 - Jun 19th, 2009 at 6:41am
You could create a ShapeNode without adding it to the diagram, and when you need to draw a shape somewhere, set the node's Bounds to that position and call its Draw(IGraphics) method.
