Normal Topic drag drop transition effect (Read 2799 times)
zoozoo
Jul 2nd, 2009 at 9:05am
hi,
i am trying to add a transition effect ( sliding node effect ) in a tree layout diagram.
the code i am using is as belows
Point p = e.GetPosition(diagram );
           DiagramNode node = diagram.GetNodeAt(p);
           if (draggedcontrol != null)
               p.X -= draggedcontrol.Width /2;
               p.Y -= draggedcontrol.Height/2;
               Canvas.SetLeft(draggedcontrol, p.X);
               Canvas.SetTop(draggedcontrol, p.Y);
               Canvas .SetLeft(node , p.X);
               Canvas.SetTop(node, p.Y );
               Layoutdiagram();
in this in have 2 issues
1. the control is getting the moving efect but the host controlnode dosent move.
2. while moving the control should it be relative to diagram or the layoutroot because the above just shifts the control by a large difference.
any advice on this will be really helpful.
thanks in advance
Re: drag drop transition effect
Reply #1 - Jul 2nd, 2009 at 12:07pm
Is draggedControl hosted inside node? The ControlNode class contains a Canvas internally, so the first position you set is relative to the node in such a case. As for the node position, you should set node.Bounds instead of its attached Left/Top properties; the Bounds setter calls SetLeft and SetTop internally and updates some additional state variables.
zoozoo
Reply #2 - Jul 3rd, 2009 at 5:36am
yes. the controlnode is of a user control. so the draggedcontrol is inside a node.
can you please elaborate more. i am not arriving at any solution to this.
thanks for all the advice
Reply #3 - Jul 3rd, 2009 at 9:33am
Could you give more details on what you are trying to implement? Why would you need to handle MouseMove and set the position of the hosted control independently from that of the host node?
zoozoo
Reply #4 - Jul 4th, 2009 at 5:34pm
hi,
i am trying to move the node/control along with the mouse pointer when the user tries to drag the node.
just want to give the user the feel of moving the tree node
could you please help resolve this...
Reply #5 - Jul 5th, 2009 at 10:16am
Are you trying to implement drag-and-drop from the diagram to another control? You should set only node.Bounds; this will also set the position of the hosted control.
If you need this for dragging nodes within the diagram, just use the built-in select and move functionality; check how it works with ModificationStart set to AutoHandles. In that case you can handle the drop operation using the NodeModified event.
