Normal Topic Increasing Font Size (Read 1587 times)
David
Jul 9th, 2009 at 8:08am
Hi
When dragging on a new shape node the font size when entering new text get's increasingly large. After the text has been entered and the shape loses focus the text reverts to the default size.
Typically between adding new shape nodes a postback has occurred.
Help?
David
Re: Increasing Font Size
Reply #1 - Jul 9th, 2009 at 8:16am
Apparently the font's unit is not preserved correctly between postbacks. Try initializing it at every Page_Load:
protected void Page_Load(object sender, EventArgs e)
	diagramView.InplaceEditFont = new Font("Arial", 12);
David
Reply #2 - Jul 9th, 2009 at 8:32am
Thanks Stoyan. The solution worked perfectly
