Normal Topic Prevent User putting Containers in Containers (Read 2469 times)
fanderlf
Jul 9th, 2009 at 2:13pm
In my app I create ContainerNodes containing some ShapeNodes. The User is only allowed to move the ContainerNodes. When I drop one ContainerNode over another, the dropped container is put in the other container (as intended).
I've tried to remove the container from the other in the ContainerChildAdded Event Handler, but that changes the size of the ContainerNode.
Is there any possibility to prohibit this behaviour? I do like the ContainerNodes very much for my Layout. They size themselves nicely and can be folded.
Thanks in advance Smiley
fanderlf
Re: Prevent User putting Containers in Containers
Reply #1 - Jul 9th, 2009 at 2:20pm
-.- OK i just found it.
I've overwridden the OnDropOver Function in my ContainerNode class. It now just returns true (which I assume means, that the drop was succesfull).
That has done the trick Smiley
Maybe someone could confirm that this is "legal" and doesn't cause any mistakes anywhere else.
Thank you!!!
Reply #2 - Jul 9th, 2009 at 2:51pm
It's perfectly legal 8)
fanderlf
Reply #3 - Jul 10th, 2009 at 10:15am
One thing that irritated me was the function name. I was searching for the OnDragDrop function. Seems you got a little naming mistake here Grin
MUDO
Reply #4 - Aug 13th, 2009 at 9:25pm
