Normal Topic HandlesStyle behavior (Read 1555 times)
Cornel
Aug 10th, 2009 at 2:00pm
Hi there,
I need to create the following behavior:
when the mouse is over a node, that node should be highlighted and it should be possible to start moving it directly (without selecting it first); in case a node was already selected then it should also be possible to resize it besides moving.
So, I would say this is a combination between MoveOnly and SquareHandles2 (but without the region near boundary for creating links).
How can I create this functionality?
Thanks in advance,
Cornel
Re: HandlesStyle behavior
Reply #1 - Aug 11th, 2009 at 7:16am
This version adds a DiagramView.AutoHandlesItem property that returns the highlighted node when ModificationStart == AutoHandles.:
https://mindfusion.eu/_beta/fcnet_autohandles.zip
Now you can implement what you need using a custom Behavior class or by setting HandlesStyle to Custom and handling HitTestHandles. E.g. with a custom behavior:
public class MyBehavior : LinkShapesBehavior
	public MyBehavior(DiagramView view) : base(view)
	public override InteractionState StartDraw(PointF point)
		int handle = -1;
		DiagramNode node = Diagram.GetNodeAt(point);
		if (node != null &&
			(node == DiagramView.AutoHandlesItem ||
			!node.HitTestHandle(point, ref handle)))
			Diagram.Selection.Change(node);
			return new InteractionState(node, 8, Action.Modify);
		return base.StartDraw(point);
// in form_load
diagramView.CustomBehavior = new MyBehavior(diagramView);
