Normal Topic SpringLayout (Read 1750 times)
Dunedan
SpringLayout
Aug 12th, 2009 at 2:05pm
I have to display a central node and the linked node around it. So I use the SpringLayout.
It works perfectly if I set a distance of 50.
But if I increase the distance to 200, the nodes are not well displayed: a part of the nodes are staying together.
I use: SpringLayout layout = new SpringLayout(1000, 200f, false, true);
What am i doing wrong ? Should I use another layout ?
Fabrice.
Re: SpringLayout
Reply #1 - Aug 12th, 2009 at 2:51pm
Are the other nodes linked only to the central node? In such case use TreeLayout with Type set to Radial. Otherwise please email us a saved diagram xml file for our developer to check that.
Re: SpringLayout
Reply #2 - Aug 13th, 2009 at 10:41am
Hi Fabrice,
The problem is that the NodeDistance value is applied only as a desired length of links between connected nodes. Nodes that are not connected repulse each other with a force inversely proportional to the square of the distance, and we rely on this to get some symmetry. However this force becomes much weaker than the spring force when you change from 50 to 200, and the symmetry is lost. Now there is a RepulsionFactor attribute in the class, but it wasn't applied at all. You can find a fixed version on the private messages page; it now multiples the repulsion force that factor and you can get a symmetry at larger distances like this:
SpringLayout layout = new SpringLayout(1000, 200f, false, false);
layout.setRepulsionFactor(3000);
layout.setRandomSeed(10);
layout.arrange(diagram);
