Normal Topic problem involving containernode, group, links (Read 1458 times)
marksolo
Suffering suckertash.....
Aug 20th, 2009 at 11:27pm
I have the following:
| Node1 |----------------------| Node2 ||    Node3    |
------------        Link1           ------------|                  |
Node 2 is attached to Node 3.  FollowMasterContainment is set to true.
When I move Node3 inside another container node and collapse it, link1 becomes disconnected, kind of, it is connected to where node2 would be before the container is collapsed but not linked to the container it self.
What do I have to do to make link1 connect to the container when I collapse the container node?
Any help is appreciated.
Re: problem involving containernode, group, links
Reply #1 - Aug 23rd, 2009 at 10:17am
You can find a fix on the PM page.
marksolo
Reply #2 - Aug 24th, 2009 at 4:36pm
Thanks Stoyo, now it is working perfectly.
That fixed a lot of problems.
