Normal Topic LinkTables links going out of tables view. (Read 3136 times)
Mrini
Aug 25th, 2009 at 1:30pm
Hi Stoyan,
Is there any way to hide LinkTables links if the rows to which it is connected goes out of view when scrolled.
Right now if I scrolled the target table and the row to which the source row is pointing goes out of table's view , the links gets displayed out of table area.
Thanks.
Re: LinkTables links going out of tables view.
Reply #1 - Aug 25th, 2009 at 2:46pm
After scrolling you might loop over the rows and hide their links if they are not visible, by calling link.setVisible(false). Visible rows are ones whose index is >= table.getCurrentRow() and <= table.getCurrentRow() + (table.getBounds().height - table.getCaptionHeight()) / table.getRowHeight().
Mrini
Reply #2 - Aug 26th, 2009 at 10:30am
Hi Stoyan,
Thanks for the reply , its working.
Mrini
Reply #3 - Aug 27th, 2009 at 12:00pm
Hi Stoyan,
This approach is working only for the rows whose indexes are less than current row as in my table each row is having different row height base on the text length. so
index >= table.getCurrentRow() and <= table.getCurrentRow() + (table.getBounds().height - table.getCaptionHeight()) / table.getRowHeight()
doesn't work Sad.
Can you guide me please.
Thanks.
Reply #4 - Aug 27th, 2009 at 3:23pm
Then you might find the last visible row by starting a loop from the current row and summing the row heights until the sum gets larger than the table's height. Should look something like this:
int lastVisible = table.getCurrentRow();
float sum = table.getCaptionHeight();
while (sum < table.getBounds.getHeight())
	sum += table.getRows().get(lastVisible).getHeight();
	lastVisible++;
I haven't tested this; you might need to add +/- 1 to the result.
Reply #5 - Aug 27th, 2009 at 3:24pm
...additionally, you must add a check if the loop has reached the last row in the table and stop it in such case.
Mrini
Reply #6 - Aug 31st, 2009 at 6:57am
Thanks Stoyan ,
Smiley its working.
