Hot Topic (More than 10 Replies) Require Colored Transparancy in ShapeNode (Read 5797 times)
Anshul
Senior Member
Sep 18th, 2009 at 10:38am
Hi Stoyan,
We want to create a shapenode with following functionality.
1) Node should be resizable.
2) Node should have Image and Text.
3) Text should be inside the node at BottomCenter position.
4) Text should have a icon associate with it at topright corner.
5) Node should be transparent but should have some shade of gray color.
6) Node's transparency should not have any effect on text and image.
Anshul
Re: Require Colored Transparancy in ShapeNode
Reply #1 - Sep 18th, 2009 at 2:31pm
It should be enough to set node.Brush to one that has semi-transparent colors, e.g.
node.Brush = new SolidColorBrush(Color.FromArgb(80, 128, 128, 128));
Anshul
Senior Member
Reply #2 - Sep 22nd, 2009 at 12:04pm
Hi Stoyan,
We have sent sample images to your support ID. Please have a look into them.
Please suggest how to get the required Shape.
Anshul
Reply #3 - Sep 22nd, 2009 at 3:11pm
Hi Anshul,
Try these settings:
var format = new StringFormat();
format.Alignment = StringAlignment.Center;
format.LineAlignment = StringAlignment.Far;
format.FormatFlags = StringFormatFlags.NoWrap;
var node = diagram.Factory.CreateShapeNode(30, 30, 80, 50);
node.EnableStyledText = true;
node.PolygonalTextLayout = false;
node.TextFormat = format;
node.ClipToBounds = true;
node.Text = "test test test test test";
Anshul
Senior Member
Reply #4 - Sep 23rd, 2009 at 6:07am
Hi Stoyan,
Many thanks for the code snippet.
With this implementation, we are still facing two issues.
1). We need text trimming when text is long(Text length is greater than the node width).
2). Text should have some spacing from the bottom; currently it is touching the node border.
Anshul
Reply #5 - Sep 23rd, 2009 at 7:17am
Have you set node.ClipToBounds = true? You could define a custom Shape with a smaller text area to move the text further from the border.
Anshul
Senior Member
Reply #6 - Sep 23rd, 2009 at 8:32am
yes I have set node.ClipToBounds = true but still text is not trimming.
Reply #7 - Sep 23rd, 2009 at 9:46am
It seems if I enable ModificationEffect = MoveShades, the drawing shown at the original location while moving a node does not trim the text. Is this what you mean?
Anshul
Senior Member
Reply #8 - Sep 23rd, 2009 at 10:33am
I have not set ModificationEffect = MoveShades still I am getting the problem. Please suggest how can I Trim the text ?
Anshul
Reply #9 - Sep 23rd, 2009 at 1:17pm
Could you copy here the initialization code for the node?
Anshul
Senior Member
Reply #10 - Sep 23rd, 2009 at 1:32pm
Hi Stoyan,
Here is the code snippet
ShapeNode mainNode = new ShapeNode(diagram);
Font nodeFont = new Font("Calibri", 12);
mainNode.Font = nodeFont;
mainNode.TextFormat.Alignment = StringAlignment.Center;
mainNode.TextFormat.LineAlignment = StringAlignment.Center;
mainNode.TextFormat.Trimming = StringTrimming.EllipsisCharacter;
format.Trimming = StringTrimming.EllipsisCharacter;
mainNode.EnableStyledText = true;
mainNode.PolygonalTextLayout = false;
mainNode.TextFormat = format;
mainNode.ClipToBounds = true;
mainNode.HandlesStyle = HandlesStyle.SquareHandles | HandlesStyle.EasyMove;
mainNode.EnabledHandles = AdjustmentHandles.ResizeHandles | AdjustmentHandles.Move;
diagram.Nodes.Add(mainNode);
mainNode.Shape = Shapes.Rectangle;
mainNode.Bounds = new Rect(new Point(50,50,50,50);
mainNode.Brush = new SolidColorBrush(Color.FromArgb(95, 211, 211, 211));
mainNode.Pen = new Pen(new SolidColorBrush(Color.FromRgb(189,186,105)),1);
mainNode.Image = new BitmapImage(new Uri(@"..\..\Image.png", UriKind.RelativeOrAbsolute))
mainNode.ImageAlign = ImageAlign.TopLeft;
mainNode.Text = “Its not Trimming”;
mainNode.TextBrush = Brushes.Black;
Anshul
Reply #11 - Sep 24th, 2009 at 8:56am
You might change mainNode.TextFormat.Alignment to StringAlignment.Near. Other than that, the text is clipped but does not display an ellipsis. We'll add some support for this and a text-margins property in a few days.
Anshul
Senior Member
Reply #12 - Oct 13th, 2009 at 1:03pm
Hi Stoyan,
Any update on this?
Anshul
